FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP
Old 08-17-20, 03:21 PM
  #166
2013FSport
2013FSport's Avatar
Received 1,530 Likes on 1,273 Posts
Originally Posted by OldLs400
Thanks for confirming. I'm about to pull the trigger on the bushings, but before I do that--how many more miles are your front tires lasting?
Futher up Jeff said he had no wear issues, so this is all performance related.
Most wear can be mitigated with proper tire pressure and toe settings. That said, if you routinely brake hard, the RC bushings should help minimize tire scrub from toe changes.
Old 08-19-20, 05:49 AM
  #167
OldLs400
OldLs400's Avatar
Thanks for that. Yes, I brake pretty hard.
I've noticed that my front brakes seem to pretty weak recently. Thinking that the Raybestos Element3 pads had worn out, I had the shop check my brake pads, but they were fine. I'm guessing that the reason has to do with the absolutely decimated front tire and it's shredded contact patch (aka the inner shoulder).
I run the fronts at 35 PSI but I will take your advice and try running them higher. I believe one of your posts said 38 or something.
I will probably get the RC-F bushings anyway just to make the car a little bit more engaging to drive.
GS4hunnit
01-08-16 03:23 PM
1jztts
Suspension and Brakes
11-12-11 12:07 PM
broken_tsi
02-23-11 05:03 PM
OCLEX03
09-10-10 10:40 AM
Quick Reply: FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP
