FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP
Old 02-26-14, 05:59 PM
  #46
ChickenIS
ChickenIS's Avatar
More photos.
Attached Thumbnails FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-img_1690.jpg   FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-img_1693.jpg   FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-img_1692.jpg   FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-img_1700.jpg   FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-img_1702.jpg
Old 02-26-14, 06:02 PM
  #47
ChickenIS
ChickenIS's Avatar
Last one. Now I will bleed the front & rear brakes since I boiled the fluid bedding these in.
BTW great update on the bushings being sold installed in housings. This would have made for a really quick install.
Attached Thumbnails FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-img_1703.jpg
Old 03-03-14, 09:17 AM
  #48
FIGS
The Maker
FIGS's Avatar
Thanks for the writeup and feedback. And just a note the bushing will stabilize the alignment but if you want a specific handling toe setting then you will have to get another alignment to center your numbers. The standard Lexus toe specs are ranging from toe in to toe out so a good treadwear setting would be to shoot for 0 toe. As far as pressing in I use a cut section of 3" thinwall aluminum tubing with machined faces on each end and a 10 ton press. its just enough undersize to get things out without impacting the bracket ID.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 07-05-14, 02:42 AM
  #49
metaleckz
metaleckz's Avatar
is there any cheaper alternative to this? im broke
Old 07-05-14, 04:10 AM
  #50
laobo979
laobo979's Avatar
Yeah don't drive your car haha..
Old 07-05-14, 05:00 PM
  #51
Jump2man3
Jump2man3's Avatar
Great choice I bought the front lca as well as rear mega arms. Very happy!!
Old 07-14-14, 01:38 AM
  #52
UniqueTII
UniqueTII's Avatar
I can't wait to install these so I can lose the death grip on the steering wheel too. My new tires arrive today so I should get everything on soon.
Old 07-14-14, 10:19 PM
  #53
jgr7
jgr7's Avatar
Just ordered my Figs front lower arm rear mount bushings as well as the Figs Sway bar bushings front and rear.
Old 07-22-14, 03:30 PM
  #54
jgr7
jgr7's Avatar
Just came fedex. These things are big, Samsung S3 in pic for size compare.
Attached Thumbnails FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-new-figs-parts-158-800x531-.jpg   FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-new-figs-parts-159-800x531-.jpg
Old 07-25-14, 06:29 PM
  #55
jgr7
jgr7's Avatar
Installed my FIGS LCA rear bushings and front sway bar bushings today.
Attached Thumbnails FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-figs-lca-003-800x531-.jpg   FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-figs-lca-004-800x531-.jpg
Old 07-28-14, 09:46 AM
  #56
WylieKylie
WylieKylie's Avatar
^Lucky, I didn't get the FIGS logo sticker on my brackets!
Old 08-03-14, 12:00 PM
  #57
JETLEX
JETLEX's Avatar
Sent mine to Mike @FIGS to have the stock bushings pressed out & the new polyurethane ones pressed in - the new bushings are the 90 durometer ones (standard).
All the local shops I took it to were afraid of ruining the aluminum bracket - the old ones were stuck in there pretty good! Stock bushings are equally spaced in the bracket. The new ones from FIGS end up basically flush on both sides when pressed in.
I haven't driven on them much yet. I did notice a slight increase in NVH, but if this helps the tires last longer & keeps the car from wondering all over the road, it will be worth it to me.
Attached Thumbnails FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-20140719_162428-copy.jpg   FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP-20140711_211008-copy.jpg
Old 08-13-14, 01:51 AM
  #58
UniqueTII
UniqueTII's Avatar
I installed my bushings along with F Sport shocks and sway bars (I already had H&R springs from the previous owner) last weekend, then got my new tires installed and had it aligned yesterday. Overall, I'm still not happy with how the car handles. My death grip on the wheel has lightened a bit, but I still don't really feel that the car is easy to handle. Thankfully, I haven't noticed a whole lot of NVH since the install, so that's good.
Old 09-14-14, 10:56 AM
  #59
slimstady
slimstady's Avatar
So what is the verdict on handling after FIGS bushings?
Old 09-14-14, 04:35 PM
  #60
slimstady
slimstady's Avatar
...also FIGS...do you know when you will have more bushings in stock?
Quick Reply: FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP
