FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP
Old 02-02-15, 05:49 PM
  #91
JETLEX
JETLEX's Avatar
joedad,
Thanks for posting up - it's nice to have all the useful, real world info we can get on this site.
I'm playing around with slightly more front camber than you, but have been happy so far with the results.
Old 02-05-15, 04:58 PM
  #92
joedad
joedad's Avatar
Thumbs up
Originally Posted by JETLEX
joedad,
Looks like you have a great set up, enjoy!! My son can't wait for spring.
Old 02-06-15, 04:04 AM
  #93
ChickenIS
ChickenIS's Avatar
I didn't get around to swapping the bushings. Our car was sold with the FIGS on it. Hopefully the next owner will be here and will read up.
Old 02-07-15, 08:57 AM
  #94
redspencer
OG Member
redspencer's Avatar
I received my set of Figs LCA bushings last week and I finally had the chance to do the modification. Though it took much longer than I would like, the upgraded bushings have been installed:
I had a very difficult time trying to loosen the long bolt that's connected to the side rail bracket as well as trying to deflect the LCAs enough to push out the brackets. I still have to torque all the nuts and bolts but after that, I'll take a test drive to see if I notice any new changes/improvements to the dynamics of the vehicle.
Old 02-07-15, 10:18 AM
  #95
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I had been hoping that these may actually provide a bit better/more direct steering feel, has anyone experienced that? I would definitely expect it under braking while corning, but just normal road feel?
Any thoughts on that?
Jeff
Old 02-07-15, 11:19 AM
  #96
ChickenIS
ChickenIS's Avatar
Jeff
The bushings will provide better and more direct steering. The front really slices into corners quickly with the factory alignment specs and these bushings. I didn't run them with a sticky tire, but noticed an improvement.
Old 02-07-15, 02:07 PM
  #97
redspencer
OG Member
redspencer's Avatar
Jeff
I just took out my car to try out the new bushings and I concur with ChickenIS' statement. The steering input has more of a go-kart feel with additional responsiveness coming from the chassis even when you subtly turn the wheel. It's doesn't have as much of an impact to the steering feel as the IS-F Steering ECU but they definitely complement one another.
Old 02-07-15, 02:13 PM
  #98
ChickenIS
ChickenIS's Avatar
Congrats on your bushing install. The tire wear is why I upgraded to these. The handling upgrade was a nice bonus.
Old 02-07-15, 02:16 PM
  #99
ChickenIS
ChickenIS's Avatar
Nice suspension upgrades BTW redspencer. Lots of goodies!
Old 02-07-15, 04:19 PM
  #100
jgr7
jgr7's Avatar
Get the FIGS bushings for the fsport sways for an even tighter feel in the corners.
Old 02-07-15, 08:45 PM
  #101
ChickenIS
ChickenIS's Avatar
^ done this on previous cars and it is the best bang for the buck hands down.
Old 02-08-15, 12:37 PM
  #102
Gville350
Gville350's Avatar
FIGs needs to offer a "master bushing" kit for the 2IS like they do for other models!
Old 02-08-15, 01:01 PM
  #103
redspencer
OG Member
redspencer's Avatar
I'm curious to know what the durometer rating of the polyethylene bushings is that comes with the F-Sport sway bars compared to the ones that FIGS offers.
Old 02-08-15, 01:49 PM
  #104
ChickenIS
ChickenIS's Avatar
I'd guess F-Sport is a hair softer. I have no idea though.
Old 02-08-15, 05:00 PM
  #105
FIGS
The Maker
FIGS's Avatar
There are just a few we are missing. But we can come close especially on the ones that matter.
most our sway bushings are 80 durometer, but the real benefit is in the lubrication features. Sticky sway bar bushings are what I estimate cause the majority of bar breakages.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Quick Reply: FIGS Front Lower Arm Rear Mount #2 Poly Bushing 90 duro HP
