Polyurethane lower control arm bushings.
Old 12-10-12, 08:02 PM
RLJ
RLJ's Avatar
Question Polyurethane lower control arm bushings.
I need a Polyurethane lower control arm bushing, can anyone help as to were I could get this.
1993 sc300 2jz-gte tt auto.
Old 12-10-12, 08:07 PM
xspsi6
xspsi6's Avatar
What year?
Old 12-10-12, 08:23 PM
RLJ
RLJ's Avatar
Lightbulb
1993 sc300
Old 12-10-12, 08:24 PM
RLJ
RLJ's Avatar
Does the supra bushings fit the sc300?
Old 12-10-12, 08:51 PM
xspsi6
xspsi6's Avatar
Order them from jegs as they are the cheapest like 60 iirc
Old 12-11-12, 05:05 PM
over40driv
over40driv's Avatar
Got mine at jegs.com.
Old 12-12-12, 03:24 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Ebay also has them ...
Old 12-12-12, 04:01 PM
SoaringSC
SoaringSC's Avatar
+1
Op, you can also get all the other bushings in polyurethane if you so desire. The company who makes them is called Prothane. From what I understand, they have internal grooves which helps them retain grease better than, say, Daizen polys. If anyone knows otherwise feel free to correct me though.
Old 12-12-12, 06:55 PM
RLJ
RLJ's Avatar
I'm checking right know, thanks for the help.
Old 12-12-12, 08:46 PM
b2designs
Former Sponsor
b2designs's Avatar
I stock the Prothane bushing. Check the link for my pricing.
http://www.b2autodesigns.com/index.p...th=13_367_1035
Charles
Old 12-13-12, 01:59 PM
scENFORCER
scENFORCER's Avatar
Charles
Anything for '99 models?
Old 12-26-12, 10:06 AM
bryan767
bryan767's Avatar
Originally Posted by TheMole
92-00 SC300/400 and 93-98 Supra front lower control arms are all interchangeable, but the 93-96 Supra NA should be the cheapest.
-2x Energy Suspension 9-13130G Ball Joint Boots (these come in pairs, replaces ball joints upper/lower)
-1x Prothane 18207 Front Control Arm Bushings kit (kit for upper/lower of both sides bushings)
http://www.energysuspensionparts.com...sp?prod=18207#
-1x Aluminum LCA inner sleeves kit (full set for both LCAs - so you dont need to burn and re-use the stock ones)
Helpful Links:
Ball Joint replacement:
https://www.clublexus.com/forums/sus...hat-works.html
Aluminum sleeves:
https://www.clublexus.com/forums/sus...de-w-pics.html
Old 12-26-12, 11:43 AM
preston145
preston145's Avatar
b2autodesign
1999sc300
Suspension and Brakes
01-23-17 05:28 AM
bacardi
02-17-12 08:06 PM
tapatap33
10-11-09 10:11 PM
Mike Hughe
09-23-03 02:52 PM
black sc
SC- 1st Gen (1992-2000)
12-25-01 06:52 PM
Quick Reply: Polyurethane lower control arm bushings.
