Brake Fluid Bleeding with Phoenix systems
Has anyone used the Phoenix systems V12-205 bleeder? I'm thinking of using this to put in some ATE super blue brake fluid when I change my pads for an easy one person operation..
Would a presure bleeder like the Motive 0101 work better? If I use the Phoenix System if I pumped the brakes 30 times with the engine off would that work?
Search some past brake related threads, I've detailed the procedure a couple times here.
If you don't have the techstream to enable air bleed mode in abs/vsc ecu then you need to manually do the bleeding.
