Is 300 BBK info help
Hello everyone I'm a new Lexus is owner and I wanted to get information on the Lexus Ls 400 bbk modification to the Lexus is 300, can some direct me to the thread , I was also wondering if the conversion is made does the rotors need to be ls 400 compliant and also brake pads for the set up to work or can the stock Lexus is 300 rotors would be enough and also if steel braided brake lines are to be used what lenght would work well for the bbk set up? As you can all see i have tons of questions so any help is appreciated
Check on my.is this thread lists tboth links for the LS400 install
http://my.is/forums/f89/ls400-calipers-444192/
Thanks for the info, whats the website for the figg adapters? And I heard there is a TRD ls400 brake caliper rebuild kit is that true? I still need more info on installing the supra rear brake calipers on the IS300
Nigel-JDMParts
Club Lexus Vendor Marketplace
32
05-18-10 02:09 PM
flat6toV8
06-21-07 07:52 PM
