Brakes and Bearings
Brakes and Bearings
I am hearing the Squeal from my front brakes in my 2006 lexus Is350, so I am getting ready to change the front brakes. Its been yrs since I have changed the brakes on a RWD vehicle and then it was 2wd work trucks where you replaced the bearings when you did a brake job. It appears that this car has a sealed bearing hub assembly, so I assume there is no reason to change this unless there is a problem?
As far as I know that is correct. Just the pads and rotors if needed. Very simple job. I did my pads and rotors last weekend in about 2 hours total (not including putting the car on stands and removing the wheels).
Be sure you buy a hardware kit for the brakes that you are replacing. These consists of boots for the caliper pins and the anti-rattle springs. They are typically available for around $15 and well worth the piece of mind. No point going to the trouble of doing a brake job, and reusing the old hardware....
silver305
06-07-13 08:02 PM
