View Poll Results: Inflate your tires to 40psi cold
I noticed a worse steering wheel vibration from my previous inflation pressure
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
0%
I noticed a great improvement in steering wheel vibration from my precious inflation pressure
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
22.22%
Voters: 9. You may not vote on this poll
Steering wheel vibration poll
pressure has helped with mine.
The weather has got cold, which dropped the the tire psi to 28. A particular section of freeway which is also the start of my commute has some imperfections, and caused a pretty decent steering wheel shake at 65.
I inflated the tires to 34psi (at the ambient temp,) and the shake is 95% reduced.
So yes, I will agree with your results and do try fiddling with your psi and it can be a factor. You probably don't need 40 though.
