Do I need to replace brake pads and rotors?
Old 12-30-12, 11:32 AM
Noeh
Noeh's Avatar
Default Do I need to replace brake pads and rotors?
My dealer said that I should replace the front brakes soon. Do you guys agree with the assessment? Also do I need to replace the rotors? These brakes have not been serviced before. Thanks!
Old 12-30-12, 05:40 PM
Gville350
Gville350's Avatar
Looks like you have about the thickness of the pad backing left in pad material. You are fine for now, but looking into a replacement set now would be in your best interest.
Old 12-31-12, 08:55 AM
Noeh
Noeh's Avatar
Thanks, should I just get new pads and use the same rotors?
Old 12-31-12, 11:37 AM
jbjones85
jbjones85's Avatar
TO tell if the rotors need to be replaced you will need to measure their thickness.
Old 01-02-13, 10:46 AM
Noeh
Noeh's Avatar
Thanks, but I don't have a micrometer. Did you guys have to replace your rotors the first you did your front brakes?
Old 01-02-13, 11:34 AM
RocketGuy3
RocketGuy3's Avatar
No, I did not. Did you get the brake dust TSIB done at any point? Because if so, they may have refinished your rotors, which would make them thinner. Good chance you still have adequate thickness left even then, though. Anyways, a mechanic will measure your rotors for you if you want (especially if he's already doing something that requires removing the wheels). Or just invest in a micrometer, they're not that expensive. Min thickness is 27 mm.
Old 01-03-13, 06:58 PM
Noeh
Noeh's Avatar
The pads have not been replaced before. I think 09+ models may have different pad design and are not eligible for the brake dust TSIB. Maybe someone else can confirm. Thanks
Old 01-03-13, 08:08 PM
jbjones85
jbjones85's Avatar
I would go ahead and just buy a cheap micrometer. You can pick one up online for less than $20. Worth having around.
Old 01-04-13, 01:21 PM
Gville350
Gville350's Avatar
A quick, free check would be to feel the edge of the rotor for a lip. If it is easily noticeable, perhaps it is time for a new set; but seeing your model year, I really doubt it.
Old 01-06-13, 06:41 PM
Noeh
Noeh's Avatar
You can definitely feel the lip, not sure if they visible from the pictures. These brakes have ~50k on them
Old 01-06-13, 06:44 PM
Gville350
Gville350's Avatar
^Well, next step would be having a shop measure them for you. Most brake places will "check" them for free...but that just might be a visual inspection versus actual measurements.
zmoneyJD
Suspension and Brakes
12-31-16 01:02 PM
kiryu
IS F (2008-2014)
17
01-26-16 01:18 PM
TLRD
09-21-15 02:15 PM
robbaric
01-05-14 02:18 PM
mansito
GX - 1st Gen (2003-2009)
14
04-15-11 08:13 AM
Quick Reply: Do I need to replace brake pads and rotors?
