BC Extreme Drop Coilovers
#31
The bottom I used about 4 screw to hold that thing on but the part that goes right under the grill always comes off cause Im using double sided tape. But its only the passenger side that comes off even though I hit both sides.
You got it off the Matco tool truck ?? What is the name of the glue ? Let me know ! I need it bad lol
#32
Sweet. Let me know when you get em on. I'd like to check it out in person if you don't mind. I still haven't seen Jakes new GS yet. I like his new wheels though ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Yo Plat. This is Carlos. I'm one of Jake's friends with the black GS3 out here in Portland. I'm ordering a set of BC coils on the extreme drop kit here hopefully by the end of the month. Going to run a 20/18 as well here. If you plan on SLAMMING be sure to get the higher spring rates. I know roads aren't TOO bad, but there's always those few areas out here.
#33
Thanks brotha ! Will order in a couple of days.
Sorry it took me so long to find out the product name. It is called rapidfix and here's a link http://www.amazon.com/gp/aw/d/B0056D66JA
#34
thanks
I'll definitely take a look at this when I take my winter wheels off. I was opening my cousins brand new BCs for his TL today and I don't think they come preloaded from the factory. I can jiggle the spring a little bit but I can easily spin the spring with my hand.
AVSRacing that clapping/clunking noise is not a normal thing. The noise is telling you that your springs preload is off. To correct this you have to jack the car up and take the wheel off.
1. Once wheel is off grip the spring with your hand jiggle it side to side or back and forth which ever your preference. If there's a lot of movement that means your preloads are off.
2. The collars at the bottom of the spring break the second one free and then tighten the first one until the the the spring has less play but not too tight you still want a little play.
3. Once that is done screw the second back up to tighten it against the first and then you should be set.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
#36
It's the shock cartridge itself going bad. I just spoke to Megan Racing about this and they told me that when the shock starts to go bad, you will get a rattle coming from the shocks. FIGS explains it well here:
https://www.clublexus.com/forums/7982637-post326.html
This was happening on my passenger side rear. I replaced the top hat, the carrier bushings, the sway bar bushings, the sway bar links, nothing helped... Finally it was recommended to me to swap the shock itself. That cured it. After only 20K miles, it was discouraging to see the shock go bad so soon.
#37
