Coilover suggestion for IS250 AWD
#31
So a few more questions then. I have a 2008 IS250 AWD and will soon be getting BCs with Swift Springs, hopefully by next week.
1) do I need an alignment after installing? If so, anything I need to know or straightforward alignment?
2) how much can I/should I lower given it's AWD if I don't want to bring on any CV or other issues, but still want an improved ride and improved look?
3) I currently have 16" winters on it, and then 17" summers (all-seasons actually). How does the seasonal change impact things (i.e. My selected ride height and requirement for an alignment)?
As you may be able to tell, I've been an all-stock guy my whole life - this is my first foray into this stuff so I'd really appreciate your expertise.
2- They say anything above 25" from ground to fender is the "safe height".. there are others that run lower with no problems and some with vibrations etc. If you want.. start by lowering your car an inch.. see how it feels.. if its alright.. considering lowering it more.. such is the beauty of Coils.. May i suggest doing this first before you get an alignment.. (a few days or so should be enough to sway your thoughts)
3- If your rolling diameters (overall diameter of your rim + tire) (25.16 approximatley for stock wheels) are the same on your winter to summer wheels (they should be as close as possible for odometer and speed purposes) then you won't have to change anything as far as your alignment is concerned
#32
2. do not go lower than 24.5" fender-ground, but since toronto road conditions are so crap i'd stay at 25 to be safe...i would raise back a little higher like 25.5 to look better else the front gonna have a bigger gap than rear
3. don't lower when you're on your snow tires...the tires are soft and hence causing the car to sit lower...wait til ur on ur 17's...that way you can get more acurate measurement
#36
Haven't been there yet will be first time but from reviews he's a legit and clean guy and my friend with his IS350 has been going there for everything. Very popular in GTA for Toyota/Lexus since he's certified.
There's also Bullock in the east-end, but it's a little more pricey there.
#37
Really appreciate the helpful advice and info, thanks! Kit should arrive in a day or two now ...
1- You definitely need an alignment after installing. Make sure your car is sitting level (side to side) after your done messing with the heights. Front and rear heights are your preference.
#38
+1 on Rick at Aussie Auto. I had my big 96K service done there (spark plugs, etc) and saved a pretty penny over dealer cost. Only downside, if it matters to you, is it's a significantly different experience than the comfy Lexus lounge (and you don't get a nice Lexus loaner). He's a good guy, qualified and competent and much cheaper than dealer.
#39
Thanks again for all your helpful advice!
1. yes, roughly 200-300km after, go to altech or ksl depending on what area you're in
downtown lexus, probably over now since i got them a while ago just waiting for a good time to install everything
#40
Forgot about this thread lol so the work was done (end of April), Rick and his buddy were great. Haven't had any issues with clunking or anything since I left his place. They were fast too considering the amount of work that was being done. Definitely going back there for my 96K (km) service, which reminds me so might as well ask here...what's in the 96K (60K) service?
I'm thinking:
* typical oil change, filter, etc.
* brake fluid flush
* brake pad/rotor change (estimate would be roughly done by then)
* tranny flush
* spark plugs
* intake manifold cleaning (might as well get it done when the spark plugs are being done)
* differential flush (awd; thought i might as well do it early since i'm doing other stuff too...want that smooth shift)
* coolant (???)
what else??!
I'm thinking:
* brake fluid flush
* tranny flush
* spark plugs
* coolant (???)
what else??!
#42
I've been at 25" fender to floor for about a year and a half now with no issues. I used to get the wobble during acceleration from a stop, but that went away once I got an alignment. I still have the vibration but it's barely noticeable. None of my passengers ever say anything about it, and they only notice if I bring it to their attention.
#43
