Stop Tech rotors?
Stop Tech rotors?
Guys its time for me to change my rotors. I have 60k miles and there is lip from the wear on the rotors now as well. I am looking to upgrade the performance of my brakes as well. I am thinking about geting the StopTech drilled rotors. ImportTuner.com has them for 205$ Front 165$ rear. Does this sound like a good investment for the cost. Of course I will also replace the pads as well with some pads that dont produce as much dust.
Also are stainless steel brake lines even worth purchasing?
My car is pretty much stock except for an intake and I will be installing exhaust, sway bars and springs in the future. I know I dont need performance brakes but what can I say the look cool.
Drilled brakes are a downgrade. They eat pads 25% faster and remove metal from something intended to operate as a heat sink. They won't stop the car any shorter either, since brake upgrades can't do that. Plus, if you ever DO use them hard you risk cracking the rotors due to the holes in them.
If you simply must do something to your rotors for looks, and you don't care about the 25% faster pad wear, go with slotted rotors. Otherwise stick to blanks.
And no, SS lines won't do anything either performance wise, the stock lines are already kevlar.
Have you read it?
http://www.ehow.com/about_5329445_sl...ed-rotors.html
And my recommendation to others is to not do so, because it contains a lot of incorrect information.
For example:
Originally Posted by Really bad ehow article
Both slotted and drilled rotors result in a shorter stopping distance. Aftermarket rotors are less prone to failure than stock rotors and carry their own warranties.
Likewise, drilled rotors are far more prone to failure- which is why nobody uses them in NASCAR and other serious racing. They use slotted rotors (but not because they stop shorter).
There's half a dozen similar errors in the story
If you'd like to read something written by an actual well known brake engineer, who has literally written books on the subject, and teaches SAE master classes as well as designing brake systems for Ford, Stoptech, and others, I highly recommend this:
http://www.scirocco.org/faq/brakes/p...n/pfpage1.html
It explains in detail what each part of a braking system does, and what it does not do.
It also explains what upgrading each part can, and can not do for you.
It covers rotors on page 4. (be sure to read the side bar on drilled/slotted).
In short though, if you want to stop shorter, bigger/better brakes won't help. Better tires will though.
The brakes don't stop the car, the tires do.
Since I was in your shoes earlier in 2012, this is what I did :
Centric (PowerSlot) slotted front/rear rotors
StopTech Street pads up front
Axxis Ultimate pads in the rear (fronts pads are on national back-order)
Stick with OEM brake lines
But if you need LOW dust, look at the OEM low-dust pads.
Places I ended up getting my brake components with online coupon codes :
buybrakes.com
importrp.com
buybrakes.com
importrp.com
I just installed these rotors on my is, now it has a weird noise when I brake, sounds like a rattle snake or something lol. Do your rotor make a weird noise when braking?
i have the stoptech slotted rotors and Akebono pro-act brakepads
no dust anymore and better brake feel/deceleration
for me it was the best choice
Also running StopTech Cryo Slotted Rotors with StopTech Pads. Held up great over the last 4 track days and perform much better than the stock setup. With the stock setup I was getting really bad brake fade after about 10 min on the track. New setup shows minimal fade over a normal 20 min run but I did also change to a racing brake fluid at the time of the swap. Really no difference on the street though. If the car never saw the track I would just be running normal blanks as the slotted rotors really eat the pads quickly.
if you are looking for long life time, blank rotors are probably going to be your best bet.
PowerSlot slotted front and rears for me as well. with the EBC red compound brake pads (low dust, extremely high stopping power) I DD my car but if I would track it, I'd swap brake fluid and I know these brakes would work great for track, "IF" I wanted anything more for track, I'd swap my EBC red compounds for the EBC yellow compounds and be set.
