Rear Traction Link
Is it advisable to get traction links for both the front and rear? I really am dying to put my coilovers on but I want it all to be done correctly. Also I think I'm just going to go with OEM 97+ replacement bushings since I am not clear at all on which ones are available/not available in polyurethane.
Ahh thank you. So for the front I suppose power steering bushins, sway bar end links and OEM bushings for the control arms are good. And in the rear traction links and OEM bushings. How does that sound? Cannot wait to see my ride on these sweet PBM's sitting in their boxes.
Update on my sc300 traction links
I ended up going with battle version and order the rear traction links. When I was attempting to install them, I noticed one of my my rear toe links were also bad. So, instead of installing them, I ordered the rear toe links also.
I am impressed by the build quality and the welds. I'm planning on installing these once I have time too.
OneWhiteSC (11-02-22)
SC300/400 OEM Traction Links identical on RH and LH?
Recently ended up ruining my rear passenger side Traction Link, I've found a driver side Traction Link on Ebay for not that much money and am wondering if I would be able to put the Driver side link onto the Passenger side without running into an issue. Asking for a friend here Thank you...
"Lexappeal
07-22-16 07:37 PM
aaronqn
02-16-16 09:19 AM
chuckdaddy
04-11-11 08:28 PM
