VSC light and Check engine light on
Old 01-22-13, 08:43 AM
jcoukos
jcoukos's Avatar
Default VSC light and Check engine light on
Had my son change the brake pads front and rear on her '07 IS250 AWD. On the second day the VSC and check engine lights came on, there is snow on the ground and it's cold out.
Any ideas?
Thanks
JC
Old 01-22-13, 10:44 AM
Kurtz
Kurtz's Avatar
VSC comes on anytime check engine comes on.
Check engine can come on for literally anything from "you are about to need a new engine" to "You forget to tighten your gas cap"
Best way to diagnose further is this:
1) Check the gas cap is tight. If not- tighten. If it is, move on to step 2.
2) Get the codes scanned to see the actual trouble code causing the CEL. Autozone type places will often scan and report these to you for free.
Old 01-22-13, 01:04 PM
Gville350
Gville350's Avatar
Ensure that the connectors to the back of each of the hubs are connected tight.
Old 01-22-13, 02:54 PM
raymond671
raymond671's Avatar
I just had the same indicators come on today and there is snow...never had this before when it snowed a couple of times and also the traction control indicator came on as well...would like to know what could cause this to happen
Old 01-22-13, 02:55 PM
raymond671
raymond671's Avatar
What did you mean by ensuring the connectors to the back of each hubs are connected tightly?...where are those located at? Thanks.
Icy350
05-21-11 04:32 AM
Dymelos
01-09-11 09:38 AM
kidluvsole
05-26-08 07:32 PM
HGill
06-15-07 10:28 PM
abear2007
Maintenance
03-14-07 02:20 PM
Quick Reply: VSC light and Check engine light on
