Rear Tire wear (with pictures)
I'm going to be getting new rear tires, and having some new tie rods installed soon. So I'm trying to get the suspension sorted out all in one shot. The rear of the car burns up inner part of the tire very quickly, even after my last alignment.
The tech said the rear is maxed out at -2.5 degrees camber. Unfortunately I don't remember the toe setting. So I'm wondering if either the toe is way off, or do I have some sort of problem with my rear suspension? The rear seems to ride a bit harsh over bumps, and feels darty over sewer covers (not sure if that's just from the tire wear). The rear passenger side tire has a crazy wear pattern. These tires were bought used at about 50% tread, and this is them after I put less than 3,000 more miles on them.
Here's the rear passenger side.
Rear driver's side, has inner wear, but doesn't have the same pattern as the other side.
i would go look for the piece of paper that gives all your alignment specs that the alignment shop gave you (or maybe they can print you out another one). Once you know where your suspension is at, replace parts as neccessary.
what suspension mods do you have right now?
-Tein S-tech springs and Kyb shocks
I asked them to print them out the spec sheet, but supposedly the printer was out of paper.
Well I just ordered a new set of tires. I'm planning on getting a 4 wheel alignment, and having them check out the suspension anyways since I'm having tie rods installed.
The tires were purchased used with about 50% tread, which was even at the time.
I hate relying on general service shops to do alignments for me. Everything else is done by ME to my car, that way I know it was done, and done correctly. I'm just not fortunate enough to have an alignment rack in my backyard haha.
Get some GOOD tires on there, and get an alignment. After a few hundred miles, keep an eye on the wear of your new tires. If something seems sketchy, take it back and have them check it. Most 60,000 mile alignments come with a lifetime guarantee of sorts. If it doesn't seem right, make them fix it.
Alright, so I finally had a shop install some new rear tires. They offered to shake down the suspension and check the brakes for me as well. They said everything in the suspension was tight, but the rear brake pads were worn unevenly. They said one side was down to 10%, and the other had more because of hanging calipers. So they said I need new calipers and rotors.
edit: Went to a real shop, and just needed rear pads. They also confirmed alignment was out of wack.
