Steering wheel shakes when I hit a bump
02-08-13, 06:42 PM
Did a search and did not find anyone with this problem. Unmolested 92 SC 400, 139k on the clock stock setup except 18 " tires, at speeds above 50 mph when I hit a bump the steering wheel shakes. Any ideas?.
02-08-13, 08:13 PM
Check the rack and pinion bushings.
02-09-13, 01:44 PM
^ +1. There's a whole thread on changing this out and the results. Check it out.
02-11-13, 07:20 AM
Thanks to both of you, I will check on that
02-13-13, 05:02 AM
Also check for worn out ball joint
02-13-13, 07:21 AM
Do you have hubcentric rings with a 60-1 centerbore?
02-18-13, 11:23 AM
I don't know and how does that matter?
02-24-13, 01:53 PM
Does it shake besides you hitting a bump? I would consider tie rods if thats the case.
02-25-13, 06:09 AM
Nope smooth as silk till you hit a bump at speed
02-25-13, 09:18 AM
Had the same issue with a set of 20s
02-25-13, 02:14 PM
then it's probably your rack and pinion bushings.
02-25-13, 02:23 PM
get the rack bushings on there they should be changed on most SC's by now.
400fanboy
13
05-24-19 07:14 PM
tb13
Suspension and Brakes
03-02-16 10:23 AM
cameratoaa
19
08-20-13 09:54 AM
rbigshow04
09-17-09 09:34 AM
Giggzz
07-11-07 08:02 PM
2006 ,
bump ,
gs ,
gs300 ,
hit ,
hits ,
hitting ,
lexus ,
ls400 ,
sc400 ,
shakes ,
speed ,
steering ,
thumps ,
turns ,
vibrates ,
wheel ,
wobbles
