Just installed BC Coilover... what you guys think?
So, I was lucky enough that my base have all the tool I needed to install my coilover... it still took me 4.5 Hrs to install it though (don't know how you guys did it in 15 mins per wheel). Anyway, saved over $400 so i'm not complaining. What you guys think? should I lower the front a little more? is the back too low? I'm getting new wheels soon so please excuse the dirty wheels.
![](https://sphotos-a.xx.fbcdn.net/hphotos-prn1/856804_703291871216_2072046070_o.jpg)
Thank Felo!
@Ismellrice Yeah I think the back is a bit too low too since the front is higher. I didn't ran into many problems installing that thing, mostly just the screw is too tight or stuck because I didn't really know what to do (Should've done some research first). Overall, it is easy just time consuming. But then again, I did have access to all the tools that needed.
i feel the vibration. ill be setting the preload and tighting the nut under the dampening settings. plus i have my camber kit to install as well. should be a productive weekend !
post pictures with your new wheels !
i ask cause i also want the run the same setup but do not use the vertex sides. but im worry if it will look weird but it doesnt look bad from your pic.
can anyone else chime in on this??
