rear lca
hey I have a quick question for you guys
when I rebuilt/assembled my rear end, on all of the bolts I greased the bolt shaft (so that the bolt shaft would not freeze to the inner bushing sleeve) and I also greased the threads of each bolt so that the nut would not get stuck/freeze on the threads
on a second thought, I think that it might have been a bad idea to grease the threads because they are now more likely to come loose. Is this true? or will they be fine greased and well torqued down?
thanks for the help
thanks for the help
GS4TEK
06-02-12 04:02 PM
