Whiteline vs Titan Sway bar set ups
Does anyone here have experience with both? I would assume Titan is the better option, but due to need to do the Supra mount conversion it is pricier. Is it worth the price difference or is it even noticeable?
I Just bought used Supra TT sways bars (115 shipped) and the mounts off parts.com ( 180 shipped) just because of the cost of the "aftermarket sway bars". Yes im sure they areworth it and better than the OEM TT sway bars but the TT sways will do just fine for the sc. paying 300plus for sways plus the mounts so mount them is pricey like you said.
I just bought the titan kit and could tell a difference for the first day. But im so low that it didnt make a difference on my application. The supra stock tt sway bars are the best bang for your buck. You need the rear subframe mount but once you have those you can upgrade to any supra sway bar. The titans are very nice and pretty thick but from my understanding just tt sway bars that are bigger and have adjustment. im sure if i raised my car up i could tell a good amount of difference but im not doing that just yet.
i believe titan sways are rebranded whitelines (quite a few titan parts are rebranded). i bought the whitelines (supra tt) and they were $100 less, same adjustability and same silver powdercoat as the titan sways. spent the difference on a set of powerhouse racing solid subframe mounts with the sway mount in place.
if you bought the sways for an sc, they are direct replacement. if you bought the sways for a supra (different rear part #), you will need the supra subframe mounts - oem or aftermarket.
I bought the whitelines from ebay and also bought the mk4 subframe mounts. I installed the mounts today and found out that I didn't need them with the whitelines. Oh well if I ever decide to go with a supra swaybar for the rear I can just replace it.
After installing the sway bars I have noticed a significant improvement at reducing body roll. Next up is the gixxer drew setup and new wheels and tires.
Has anyone had the SC-specific whitelines vs the Supra-specific sways/titan adjustable? I have stock TT sway bars from my Supra and for the cost of rear Supra mounts, it's almost the same price as an SC specific rear bar from whiteline.
just want to make sure I buy the better product.... and this car will be put on a road course. The adjustable whitelines seem to be a good choice if I just want to buy once.
Visual reference. (off of CL sway bar thread)
![](https://lh5.googleusercontent.com/-bSXF6YUKeBE/TSYe0MaWdmI/AAAAAAAACdo/8UTlR7TFehc/s512/Sc%2520vs%2520supra%2520sway%2520bar%2520rear.jpg)
