1998 SC300 Popping sound, Need advice
Old 03-22-13, 07:50 PM
mikevandam
mikevandam's Avatar
^^^ +1
Whiteline has a good line of bushings. Also if you can, re-torque the subframe too. I found myself doing that and solved my creaking and popping sound as well as stability.
Old 03-22-13, 10:15 PM
Luxor
Luxor's Avatar
Could be a simple fix like the brake caliper fittings. https://www.clublexus.com/forums/sus...noise-fix.html
Old 03-28-13, 03:53 AM
glbg
Heel & Toe
glbg's Avatar
I ordered this from Figs. Is this the right parts for the steering rack bushing?
Posted from ClubLexus.com App for Android
Old 03-28-13, 04:47 AM
glbg
Heel & Toe
glbg's Avatar
Sorry forgot the detials. See below Part details:
SuperPro Polyurethane Suspension Bushings
Steering Rack Mount
Part#:SPF1193-50K
Old 03-29-13, 03:03 PM
glbg
Heel & Toe
glbg's Avatar
Steering Rack Mount
Part#:SPF1193-50K
Bushing above installed but still has popping sound . next stop lca bushing.
Old 03-30-13, 03:13 AM
glbg
Heel & Toe
glbg's Avatar
Where can I find the torque specs for the LCA? I read the DIY it was not mentioned there.
Old 04-24-13, 06:31 AM
glbg
Heel & Toe
glbg's Avatar
Attached picture shows the front driver side LCA looks like. The bushing is already worn out. Since the car has high mileage too, I think am better off replacing both front LCA with the Supra TT LCA.
Old 04-24-13, 06:34 AM
glbg
Heel & Toe
glbg's Avatar
Sorry...picture attached.
Old 05-02-13, 07:00 AM
glbg
Heel & Toe
glbg's Avatar
The popping noise just strangely disappeared. My LCA is still in transit from vendor.
Old 05-02-13, 10:17 AM
SC4Paulo
SC4Paulo's Avatar
subscribed. My car has the same noises, i was thinking bushings as well since my LS needed bushings and made similar noises. Ill be checking my bushings out later today after work.
Old 05-03-13, 06:23 AM
t4l
t4l's Avatar
Mine started making the same noise. My LCA bushings are bad like the ones pictured.
Old 05-07-13, 11:49 AM
SCV8
SCV8's Avatar
They made the rear bushing paper thin for comfort, Supra ones are normal, way better.
I replaced the bushings, but the balljoints soon went out; better to replace the entire arm.
Old 05-08-13, 12:47 PM
glbg
Heel & Toe
glbg's Avatar
Both front LCA arrived yesterday. I ordered the OEM for 1998 SC300(Part#'s: 48068-29215 (RH) & 48069-29215 (LH) and not the Supra TT.
Old 05-10-13, 01:05 PM
glbg
Heel & Toe
glbg's Avatar
Do you need to replace the rubber stopper (part#48657-24020) between the bracket and the LCA. Also the clip on the ball joint? I might delay my install to get these parts.
Old 05-10-13, 05:48 PM
MMCtuner
MMCtuner's Avatar
Did you re torque the crossmember?? I had this popping sound before.
Quick Reply: 1998 SC300 Popping sound, Need advice
