Rear TRD Sway Bar Snapped!
Old 04-03-13, 08:20 PM
1sWt2GS
1sWt2GS's Avatar
did your mechanic snap them and just blame you?
Old 04-04-13, 08:48 AM
sakataj
sakataj's Avatar
Originally Posted by blacksedan
that hue of blue is kind of off. are you sure it's TRD?? Mine is a bit brighter
yeah my TRD sways are much brighter also
(OLD PICS)
naw i noticed his a little flat and it looks a little like Cusco's but im sure he knows his car better than us and if he says they are TRD blues they probably are just old,faded,and dirty i guess. sucks bout that breaking OP this one of the best mods i have done for handling
Old 04-04-13, 10:54 AM
GSquicksilver
GSquicksilver's Avatar
sakataj
what bushings are you using? the stock rubber or did you manage to find some polyurethenes to fit?
Old 04-04-13, 11:00 AM
sakataj
sakataj's Avatar
Originally Posted by GSquicksilver
sakataj
the TRD's come with their own bushings, so im using the ones they supplied.when i was stock i was using the Daizen ones, why, what are you using?
Old 04-04-13, 01:31 PM
neegroy
neegroy's Avatar
well i mean if OP you were really that low, wouldnt your exhaust pipes also be done?!
Old 04-04-13, 02:14 PM
sakataj
sakataj's Avatar
are you serious? he doesnt mean he was so low the sway bar dragged and broke,he means from the constant back and forth swaying and the pressure it creates it broke
if it was how you described the whole rear would be done as the sway bar is up in the rear end and not easy to get to, to scrape.....almost impossible without ruining the car
Old 04-04-13, 04:57 PM
LexFather
Guest
Posts: n/a
Years ago when trying to Slay the Dragon's tail road I noticed a clunking sound on the way home and the car felt looser. Took it to Hennessy Lexus of Gwinnett (the best dealer around) and I snapped the front TRD sway bar They had to fuse it back together and it was back to normal.
Old 04-04-13, 06:27 PM
2jS160
2jS160's Avatar
^ that's very interesting that they can fuse a snapped sway bar. How much mileage did you put on the repaired sway bar?
Old 04-05-13, 08:35 AM
sakataj
sakataj's Avatar
pics...............?
Old 04-05-13, 11:24 AM
GSquicksilver
I'm using the rubber bushings that came with my TRD's but they are showing signs of age. I was hoping to be able to put some polyurethane bushings in there to couple with the TRD sways.
Old 04-05-13, 02:43 PM
LexFather
Guest
Posts: n/a
Mahn this is like 7-8 years ago... I found my install thread, 2002
https://www.clublexus.com/forums/sus...-the-same.html
Old 04-06-13, 11:23 PM
GTSLEX
GTSLEX's Avatar
Did they just weld the bar back together? how did the weld hold up after some hard driving?
Old 04-08-13, 07:36 AM
sakataj
sakataj's Avatar
i have pics from my builds years 8-10 ago but i understand man it was a long time ago and a lot of you old cats werent into photos back then. i wouldn't have allowed them to weld that bar again as it would always be a weak point and susceptible to breaking again
Old 04-09-13, 06:03 AM
JeffTsai
JeffTsai's Avatar
Keep in mind everyone. The reason you're snapping the TRD bar is because most of the suspension of everyone here is probably going to be on the softer side. This means the sway bar is going to be taking a HELL of a beating. Say for example you put the TRD on stock GS suspension. The car is going to have much less body roll, but guess what. The sway bars are solely taking on that load, and that's probably well beyond their designed strength. Now, say you couple that TRD bar with some stiff coilovers. Now you're distributing the body roll load across the coilovers and sway bars. Much less likely chance of breaking the sway bar in this case. The spring rate on my coil overs have always been around 18/16k front and 14/12k rear. I've never snapped any of my TRD sway bars.
The solution for those of you that prefer a softer suspension, don't get the TRD sway. Get something softer that will comply with the softer suspension you have. Yes you will lose some of the great TRD body sway reduction, but you won't be snapping sway bars.
snakehead
Suspension and Brakes
14
02-16-11 10:17 PM
newgsman
18
07-09-09 05:16 PM
sam430
38
05-19-09 04:56 AM
GS4
02-07-06 04:01 AM
UTGS400
12-23-05 09:09 AM
Quick Reply: Rear TRD Sway Bar Snapped!
