HELP. very bad alignment after lowering h&R
I think because the wheel is about 0.5 lower that cosed the camber problem
So how can i rise it up to make all wheel even and i think the camber problem will be solved
Any ideas?
Any ideas?
i must have done something wrong .
It almost sounds like you took the spring seat out of one side. It could have come off with the factory spring on one side and stuck to the strut on the other (they're usually about 1/2 inch). Would think you would have some noise if this was missing though.
I have my H&R springs in for a week now and my left front is about .3-.4 inches lower than the right as well.. I know i installed it correctly and everything is in place. The ride is fine, but mine is also a little lower. I read on other forums that other people had this problem with H&R springs too so it seems more common than error... But if it was an error I wouldn't know where to look because everything went in as it came out...
DPK*David
11-19-15 01:28 PM
