just cut that thing off it does next to nothing anyway. i tried to take the hub off as well and its pressed on there from the factory. I completely cut mine off with a grinder, just to make sure you dont cut to deep and cut the hub carrier. good luck
Thanks guy for all the help. Turned out the noise was a combination of untrimmed dust shields and a seized rear caliper. I did try to install the new dust shield but the wheel trick didnt work, so i gave up.
