What strut bars fit on the SC 300/400
The cheap ones they sell for Supra on Ebay will work. You will need to add 2 washers on the Strut bolts to give it more clearance. It will fit fine with more than enough threads left.
Rob
Rob
Originally posted by ACleanSC4
Year SC - 92
Model - SC300 & SC400
What type of Strut bar - JIC and Cusco
Any issues you may have - had to remove emblem off of the SC400.
Year SC - 92
Hmmm, I just tried on the JIC bar on a SC400 and it didn't even come close to fitting with the short angle on the driver side...the long angle side hit the intake tube and wasn't even close to fitting. When I switched it around, it seem to ALMOST fit but it need a spacer...
I have found a easy spacer solution for both the SC300 and the SC400...I will be posting picts pretty soon along with parts numbers...
I also noticed that some of you put regular "washers" on there...uh, that's not a good idea folks...I also noticed that the nut was also at the very top of the bolt....luckily, my JIC coilovers have longer studs so I think with the spacers that I'm doing, I should still have plenty of threading...
Originally posted by Vegassc400
Has anyone found a strut bar that fits the SC400 with no modification? I like the emblem on my engine and don't want to remove. it.
So you'd rather keep a completely useless emblem on top of motor that you look at how often (???) over a functional piece of suspension? Come on....even if it DID fit over the logo, you wouldn't be able to see the logo because the bar would be covering it!
Adjustable STB
BTW, adjustable STBs are quite useless, unless each side of the bar is held by at least 2 bolts, the single bolt will act as a hinge. TRD's JZA-80 bar is the best design since it's non-adjustable, but I guess it doesn't fit SC (it does on my '95 LS400). So, the question is, is there a non-adjustable STB that fits SC ?
