Fsport springs on awd question
I'm really considering buying the fsport springs for my awd just because I want a small drop. Do you think I should just have the dealer install them? Also how many miles have people gone with these springs having no problems?
OP, I suggest you look at pictures of an AWD dropped on F-sport springs before making your purchase. It's not worth it in my opinion. Spend a little more to get Megan EZ coils, and you wont regret it down the line.
The only reason I don't want coliovers is cause of the winters here. I don't want them to rust and have the sleeves seize on me. I'm also worried about the vibrations, I don't want my car shaking when I drive
I have the F-Sport set up and I love it. It's not too low and gives you a nicer look. I bought it here on the classifieds. If you get a set that's already fully assembled, the install is super easy!
I have the RWD IS350, but I've seen a thread on here where someone with a Matador AWD do a f sport setup. It looks nice.
No vibrations, but the ride is a little more bumpy then expected. I chose to go with this setup to avoid the extreme camber wear on the tires. Right now I'm running -1 for the front and -1.5 for the rear. And my toes aren't bad either.
Have you seen pics of them though? There are people running them on AWD. So you should do a search and make sure it's for you
F-sport springs look decent on RWD. AWD models are higher off the ground. F-sport springs make the AWD look like stock RWD height.
Im tucking tire with 20s and I only have between -2.2-2.5 for the front and rear.
That's understandable, but don't say I didn't warn you
OP make sure you know what you want and what your car will look like. I debated Fsport springs too and decided to get coils.
The dealer quoted me almost 700 for spring install and alignment. How long do you think the awd can be lowered for without any mechanical problems caused from the drop?
