Megan Racing front upper camber arm
Old 04-14-13 | 07:24 AM
reyoasian's Avatar
reyoasian
Default Megan Racing front upper camber arm
Stumbled upon this....seems Like new? Hopefully its not actually pink =/
Http://www.meganracing.com/product_d...=1509&catid=91
Lexus IS250/350 06-13 Front Upper Camber Arms
Model Number : MRS-LX-0313
Car alignment is absolutely crucial when modifying your car. Alignment can effect every aspect of your driving experience, from straight line stability, under steer, over steer, acceleration, braking and tire wear. Although stock components allow slight alignments from the stock suspension settings, they often are not able to properly align the car after the suspension has been modified. From the factory, most cars are set to have under steer and for optimum tire wear at stock height; under steer is often undesired from a performance standpoint and almost all performance driven applications are lowered.
Megan Racing Inc. has developed reinforced and adjustable control arms to accommodate the needs of the aggressive and performance oriented tuner. Being constructed of a Lightweight Steel-Alloy which is able to withstand the stresses of extreme competition, these arms are powder coated with a 3-Stage process to ensure durability and protection against the elements.
Alignment is crucial to the handling of your vehicle. Remembering that the only thing that touches the ground is your "Contact Patch" of your tires you have to make sure that your tires and wheels are doing exactly what you want. With this you must make sure you have the proper camber, caster and toe as well as make sure they are all working together and not against each other.
These Front-Upper A-Arms allow the adjustment of more Negative Camber in the front and are perfect for any driver looking to properly tune their machine for performance. The Powder coated Steel Construction also adds for durability and wear against demanding competitive conditions and rough driving surfaces as well.
- Allows for additional NEGATIVE and POSITIVE camber correction to properly tune camber for suspension travel.
- Polyurethane-Hard Rubber compound removes any "slop" in control arm motion.
- High-Strength Steel-Alloy designed to be light weight yet durable.
- 3-Stage Powder coating process to protect against the elements and offer a brilliant pink finish.
- Rubber viscosity is around 2000KGS
- MSRP: $381.00
Old 04-14-13 | 06:00 PM
Gville350's Avatar
Gville350
About time! But too late for me, already got the SPC adjustables mounted in ISF uppers.
Old 04-19-13 | 08:15 AM
reyoasian's Avatar
reyoasian
Gonna look more into this when getting coils...
MilkMonstr
11-24-17 12:44 PM
organicali
Suspension and Brakes
11-30-16 07:05 PM
Deem831
01-24-15 09:29 PM
weesped
11-22-11 01:22 PM
