Installing Coils, need camber?
Old 04-16-13 | 06:20 PM
KL411's Avatar
KL411
Default Installing Coils, need camber?
Hi all,
Need some expert opinions please, i've bought a set of used BC coils for my 07 IS350. I'm going for a subtle drop, probably a finger gap or two above the tires. My question is, should i purchase a camber kit and have the shop install all at once or install the coilovers and do alignment to see if there's need for it?
Old 04-16-13 | 06:26 PM
projectdna's Avatar
projectdna
you can go reduce the ride height by as much as ~1.25" and still have in-spec camber.
now, if you're the "measure twice, cut once" type of person, in which case you should just get everything done all at once and call it a day.
Old 04-16-13 | 07:25 PM
whitebeast's Avatar
whitebeast
with your drop, you gonna need camber set but it's all depend on size of your wheel
Old 04-16-13 | 08:09 PM
KL411's Avatar
KL411
Thanks for the info Projectdna, currently i have stockies, is camber for the rear necessary as well?
Old 04-17-13 | 03:17 PM
Gville350's Avatar
Gville350
NO! You do not "NEED" camber adjustable arms or anything. I rode on BCRs dropped 2"+ on stock wheels with 2.8 degrees negative camber in the rear and 2.3 up front. I had Lexus do any alignment after the install and I got 30k miles on my 300 treadwear rated BFG KDW IIs.
What you will want to do is get an alignment after the installation to ensure everything has seated properly and that you'll be rollin proper.
GL!
Old 04-18-13 | 09:50 AM
KL411's Avatar
KL411
WOW, that's impressive, were there any rubbing issues with that kind of drop on stockies?
Old 04-18-13 | 05:56 PM
Gville350's Avatar
Gville350
^Yes, but only with the fender liner; minor rubbing on harsh cornering or bad bumps. Nothing harming the tires or drivability.
Benoit
IS - 1st Gen (2001-2005)
04-14-19 07:05 AM
IS250Kevin
Suspension and Brakes
07-10-10 12:22 PM
pizdets17
10-22-09 09:53 AM
ekrebs
01-15-09 07:51 AM
Joshwa
10-16-06 11:29 AM
