Don't Let this happen to you.
I attempted the sawzall method and it didnt work out too well, so i ended up dropping the subframe to take to a friends shop to get it torched out.
![](http://i2.photobucket.com/albums/y23/sprint13/406AE6CC-F99C-4252-B838-37642E259EDC-21433-00000C46CD811062_zpse5242685.jpg)
Update:
Took it to my buddy's shop tonight and it took him 10 minutes to remove it with a angle grinder.
Update:
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
My 93 has terrible bushings, I ordered the poly replacements but unfortunately need to retain the sleeve. So instead of an easy press out I have to get them into the shop and burn them out, propane doesn't work, had 2 bottles wasted to not burn out a single bushing. Havent been able to find control arms in my price range though.
Update: Car is back on the road, and wow......it feels like a Lexus again on the highway. ![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Now i need to install my steering rack bushings.![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
That sounds horrible, just keep looking in the classifieds, that's where i found mine.
I used the propane and it worked fine. Took a bit to get started at first until i figured out what to do. The trick is to heat both sides and grab the inner sleeve with some pliers so you can work it out. Once the sleeve is out the bushing will burn quite quickly without the aid of the torch just keep adjitating the rubber with a long screwdriver until its all gone.
lexo101
Suspension and Brakes
07-01-14 04:42 AM
