BC Coilovers
Old 04-17-13, 10:47 AM
LexoticJ
LexoticJ's Avatar
Question BC Coilovers
Quick question as I order my kit... I have a 2007 is250 rwd and will be purchasing this kit..... should I go with the standard kit which I believe is 10k/8k or do the custom 12k/10k to tuck the 20s that I am currently running?
wheels are 20x8.5 in front and 20x10 in rear
already currently lowered on Road Magnet springs and just need to know if this spring rate is going to need to be change for the static appearance I want to obtain...
Old 04-17-13, 02:03 PM
Gville350
Gville350's Avatar
After having owned a set of BCRs myself for over a year with a custom ordered set at a 12k/8k rate, I had wished I had went with a 14k/10k rate. Current setup is just not enough for me I guess.
Old 04-17-13, 08:11 PM
iRyan
iRyan's Avatar
I'm running custom 12/10k rate...i love the feel and the stance...it depends on how aggressive...if you are super aggressive then go 14/10 if not then 12/10 should be perfect...
Old 04-17-13, 08:28 PM
LexoticJ
LexoticJ's Avatar
Thanks guys. I will definitely go with the 12k/10k then.
Old 04-18-13, 08:52 AM
SoSickG35
SoSickG35's Avatar
just ordered mine. I went with 12/10k and im pretty aggressive
Old 04-18-13, 08:56 AM
aznoutkast
aznoutkast's Avatar
sorry im new about the spring rates... noob question alert..but how does spring rate matter to fitment?
Old 04-18-13, 11:06 AM
iRyan
iRyan's Avatar
the higher spring rate the stiffer it is so it don't bang on your rim...in a nutshell
Old 04-19-13, 06:41 AM
LexoticJ
LexoticJ's Avatar
cool but how much wheel can i tuck on these 20s and should i just go ahead and buy a rear camber kit iRyan?
Old 04-21-13, 06:15 AM
iRyan
iRyan's Avatar
i tucked pretty good and believe i can still go down more if needed...look at my build page you should see some pics of my car....I would say if you want to slam then definitely get the camber kit
KamiSpeed
Club Lexus Vendor Marketplace
141
07-01-16 01:35 PM
CalitriSC
Suspension and Brakes
11-27-13 07:50 PM
KhoaNguyen
11-05-12 04:28 PM
KhoaNguyen
20
09-07-12 12:26 AM
AUSgsVIP
05-31-09 10:04 AM
Quick Reply: BC Coilovers
