how does my alignment look? 09-13 AWD
I've been having excessive wear on the inside and outside edges of my tires for a while. This has been happening despite 38PSI all around and tire rotations every oil change (5k miles). I hit a curb the other day so I finally decided to bring it in for an alignment. How does my alignment look? Should I worry about the thrust angle not being 0.00?
Comments appreciated. Thanks!
Are you on stock suspension? Just curious because I just replaced the shocks in my rear and I didn't see any adjustments for toe in the rear and I'm wondering if I should bring it in to get it checked since I see that they fixed the toe in your rear.
There are adjustments for toe in the back.
OP, I wouldn't worry about the thrust angle. However I wouldn't be happy with the toe on the rear if it were my car. I'll bet the shop just plugged in factory limits and banged on stuff until it was green, and you can't blame them for that, but regardless of positive or negative toe eats tires. So if -.11 degrees on the left before alignment is bad then +.18 on the right after alignment is still bad. I'd shoot for less than .05 on all 4 corners.
I'd also prefer the camber to be better matched from one side to the other both front and rear, but camber doesn't eat tires nearly as badly as toe does. If you are super concerned about tire wear then you would be better off with camber less than -0.5 all the way around.
When I'm shopping for an alignment I tell the shop what I want, and let them know I don't care what the factory limits are (granted some shops don't like my attitude ). Manufacturers (including Toyota) have been known to loosen the factory limits after they find out that a high percentage of cars are coming off the production line with alignments ouside of original spec.
