suspension question from the new guy
Old 12-28-02, 05:13 PM
clean540
clean540's Avatar
Default suspension question from the new guy
Hello, can you recomend some suspension setups that has the ride comfort thats pretty close to stock a drop that isnt too dramatic. Less than a 1" drop all around maybe. This would be for a 2000 gs 300. 19" rims will also be added with the suspension.
Thanks.
Old 12-28-02, 05:32 PM
Johnny Mo
GX and 2IS Moderator
Johnny Mo's Avatar
Default L-TUNED
Welcome to the board! If you are looking for nothing too dramatic then L-Tuned is the way to go. Approx 1-1.25" drop. It does not compromise ride quality significantly (although with 19"s it might more than my 17"s) You can go to the MEMBER gallery and look in my album and you'll see both before and after shots on the L-Tuned drop from pretty much the same angle/same location. THere's not much out there that goes less than 1" unless you do fully adjustable coil-overs - which are $$$$.
Old 12-28-02, 08:45 PM
TRDGS3
TRDGS3's Avatar
I would buy the L-Tuned shocks and Eibach springs, TRD is the way to go for things such as strut bars, sway bars, lower member braces. If you cant get TRD get Toms or even Cusco. Or you can just say screw it and cut the springs and have a crap ride.....lol....
-KRis
jpganman
Suspension and Brakes
13
09-29-07 01:43 PM
kutscher
17
11-20-03 05:58 PM
5.9rotorM3
07-29-02 06:53 PM
enginyr
12-05-01 09:50 PM
gwu128
11-05-01 01:14 PM
Quick Reply: suspension question from the new guy
