Fsport Sway bar installed: Clunking sound
My set just arrived today!
Re: the anti-seize compound, what do you mean and why? Hadn't considered that but will if it's something i should be using. Thanks.
Anti-seize on the threads of the end links to keep the nuts from rusting or getting stuck on there. Seems like a lot of members end up having to hack up their old end links in order to get their new sway bars installed. I had to take a Dremel to BOTH of mine to get the old end links removed from the sway bar. I even had the bar removed from the car when attempting to remove the end links; didn't help.
Ah, makes perfect sense. Thanks I'll make sure I do that.
i see, thanks for replying.
my lower control arm is seize up too, i end up buying a lower control arm from Sewell and tons of bolts.
i have a feeling my end link would be the same
