brake flush, still NOT tight!!
hey guys,
So I just did a brake flush and my brakes are still NOT the tightness I was hoping for. I can tell the motion got much "smoother" but the feel is still "spongey." I know I did not let air in the system because I kept a close eye on the master cyl. and also closed the valve on each release. I even went a step ahead and filled the drain bottle with new fluid on each wheel so if it did suck anything back up it would be fluid not air.
any suggestions? My rotors are fine and brake pads are new.
Posted from ClubLexus.com App for Android
Originally Posted by jadu
did you have a buddy pumping the brake pedal in the car?
i had this same problem after this shop removed my front caliper and rotors after i changed out my stock studs for extended ones. initially i thought air got into the system so i had them bleed it out several times, they said they were positive no air was in there but it was still spongy. so i took it to another shop where they looked at my problem more closely and they said that the pin on the driver side of my caliper had seized so it wouldn't allow the piston to depress all the way and giving it a spongy feel. i'm not sure what the conditions are on your calipers but i had to replace both my fronts because of it. this may or may not be your problem but just thought i'd share.
actually I'm not sure if they depressed the brakes to see if it was squeezing, but they just basically showed me my caliper after they removed it from the car and the bolt/pin thing's head looked like it took a beating, like it was stripped and all that stuff. had a feeling that the previous shop that worked on it did it. but the guy told me that sometimes that happens to calipers and you can't help it, because water, rust or other contaminants might get in there through the usual wear and tear stuff and cause the pin to seize.
any other opinions/suggestions on this issue? my brakes are about 1 and 1/2 inch from the floor when coming to full stop. is this normal? is there any other way to adjust the tightness?
my brother had a issue with his brake too and he end up changing the brake booster and then come to find out that it wasnt even the problem it was the caliper braket that was sieze up with no grease in the bolts
the bracket only ;like 30 dollars but just check it to make shure its not seize up instead of buying a brake booster for like 700 dollars and feeling salty like my brother did lol
