Rear End Unstable
Old 04-28-13, 03:33 PM
G4lexboi
G4lexboi's Avatar
Default Rear End Unstable
Sup guys I'm new to posting on this site I have a GS400 and I'm have some sort to problem with my suspension (rear) mainly the car recently started to sway or get loose in the rear I go for alignments but that doesn't help so I then replaced front and rear sway bar busings w/ polyurethane bushings still bad. I just bought toe links to replace my old ones so hopefully there'll work. Any other suggestions on what it may be??? Car not lowered new struts all around I do have 20x8 front 20x10 rear I believe I'm on 245 35 20 in rear 2nd pair in 10 months but worse recently.
Old 04-28-13, 09:39 PM
chicov8
chicov8's Avatar
i had problem like that but its gone after i changed struts (old struts were shot)
Old 04-29-13, 07:31 PM
repugnante
repugnante's Avatar
Check your knuckle bushings. I can guarantee you that they have play. Read the thread by Lyonsker in the suspensions forum.
Old 05-01-13, 12:19 AM
Evlc36
Evlc36's Avatar
I replaced all bushings in the rear and it fixed the problem - upper and lower arm bushes, knuckle bushings, traction arm busings, toe links etc.
Old 05-01-13, 11:05 AM
BayAreaLex
BayAreaLex's Avatar
Yes, these can cause the rear to feel unstable. Usually when they have play, you can hear the faint popcorn popping kind of noise in the rear when going over uneven surfaces. I'm not sure what the lifetime of these things is, but mine were shot after 90K miles. The stiffer the suspension and the lower profile the tires, the more evident it is once they start to develop play.
Old 05-01-13, 01:40 PM
G4lexboi
G4lexboi's Avatar
Thanks guys, I changed struts last year so ill just change what you told me. Hope it works! I was thinking bout replacing inner outer tie rods and lower ball joints. What you think?
Old 05-01-13, 02:07 PM
G4lexboi
G4lexboi's Avatar
Will this work for the knuckle issue ?
http://www.ebay.com/itm/690X2-GS300-GS330-98-05-IS300-01-05-Rear-Axle-Carrier-Bushing-Kit-Left-Right-/170916476681?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D163%26meid%3D7358471137727201321%26pid%3D100005%26prg%3D1088%26rk%3D1%26sd%3D170759488720%26
Old 05-01-13, 02:16 PM
G4lexboi
G4lexboi's Avatar
I just bought a pair of the Carrier bushings also bought toe links earlier last week
Old 05-01-13, 10:31 PM
BayAreaLex
BayAreaLex's Avatar
Originally Posted by G4lexboi
Nope, those are not for the knuckle/carrier.
What you are showing is for the trac-link.
Here is what you want for the knuckle/carrier: http://www.ebay.ie/itm/ws/eBayISAPI....d=474837003376
Old 05-02-13, 03:53 PM
G4lexboi
G4lexboi's Avatar
Ok cool. I get some.
Old 05-03-13, 05:27 AM
neegroy
neegroy's Avatar
how many do we need? only one or a pair im about to order them too
Old 05-03-13, 06:41 AM
repugnante
repugnante's Avatar
^ You need a pair. One for each side. Make sure that they are the knuckle/pillow ball bushings and not the poly ones. The poly ones will not hold up. If you have two large sockets, a long nut and bolt, you can do both sides in about an hour.
Old 05-03-13, 02:20 PM
G4lexboi
G4lexboi's Avatar
Just ordered mines!
Old 05-09-13, 07:24 PM
BayAreaLex
BayAreaLex's Avatar
Just ordered mines!
Let us know how it goes! I still haven't found time to get to mine.
joebor1776
Suspension and Brakes
03-20-16 09:53 AM
FIGS
GS - 1st Gen (1993-1997)
26
12-22-13 10:48 PM
StevieA
12-05-12 04:46 PM
renato902
08-02-12 02:01 PM
hobojoe
09-22-09 05:59 PM
Quick Reply: Rear End Unstable
