Uneven Rear Brake Wear
Old 06-18-14, 02:34 PM
Gville350
Gville350's Avatar
^The pin he is referring to is the floating pin that the inner/outer portions of the calipers move in/out on. The seal that is supposed to keep moisture from entering that floating pin chamber doesn't seal well after a while and causes water to enter the chamber. Thus if you try to remove the two halves, and cannot...they have literally rusted together. I had to source two new OEM calipers because of this issue, even after the dealership did the TSIB on my Lexus previously for the last owner.
Old 06-19-14, 12:03 PM
FMJ IS
FMJ IS's Avatar
for those who don't have warranties anymore, is the caliper rebuild-able?
this is a IS350 problem only right?
Old 06-20-14, 09:15 AM
Noeh
Noeh's Avatar
My second option was to replace with remanufactured centric calipers from Rockauto, less than $100 per side.
Old 06-21-14, 11:05 AM
Gville350
Gville350's Avatar
Yes, but it is only possible if the unit isn't 100% rusted up. And even if you are able to separate the two halves, it still might cost more to repair the bad caliper correctly than purchase a reman unit.
The IS350 rear calipers have a different design than the rear IS250...so yes. BUT, the front calipers on the IS250 have a similar design (but larger) and can be susceptible to similar issues too.
azipod
10-23-18 07:15 PM
BMW7_LS430
04-22-18 06:56 PM
JohnLX300
Suspension and Brakes
09-24-13 03:45 PM
ALLWiTE2JZ
11-18-12 10:35 PM
ycp
09-08-06 10:38 PM
Quick Reply: Uneven Rear Brake Wear
