^Despite the name "pillow" used, it is actually a spherical bearing and people say they make more noise when compared to an "OEM" rubber-type mount. The coilovers themselves, if installed correctly, make no more noise than the OE suspension components. If you want a quiet ride, just get the rubber upper mounts or get a set that makes you re-use the OEM top mounts.
all coilovers should be quiet if it has the rubber bearings...if yours make noise make sure to check installation to see if it was done correctly...my BC don't make no more noise than OEM
My BCs dont make any noise. Tires can make noise depending on brand and model. The only thing making noise from my car is the damn dash(sometimes), avs visors(upgrade to jdm soon), my exhaust and system.
