Sway bar kit
#226
I'm confused why everyone is saying the rear bar is 20mm? The listings all say 16mm rear?
I want to pick up a set but need to make sure I get the right sized bushings. Those who have bought these, can you guys please check the sizes?
http://www.ebay.com/itm/321688626225?item=321688626225&viewitem=&vxp=mtr&rmvSB=true
http://www.ebay.com/itm/Swaybar-Fron...xU-etT&vxp=mtr
#227
Front Rear Sway Bar Stabilizer Anti Roll Arm Fit Lexus 98 00 GS400 98 05 GS300 | eBay
#228
I contacted the seller "speedyracerparts", he confirmed that they only have the 16mm rear bars in stock at the moment. He cannot say when they'll get more 20mm ones and that it could be a month or more. He said they just got a shipment this month but didn’t receive any 20mm ones.
So if any of you guys are planning on getting this kit, I’d hold out till the larger bars are in stock.
Also - I'm certain that speedyracerparts and emusa are the same sellers. Both are out of Indiana
#229
update
i made the mistake of posting a new thread instead of just updating to this thread. so i bought both sway bars from emusa off of ebay. i bought them b/c they were advertised as 30mm front and 20mm. rear. so i got them in last week to discover that the front was correct and fit in the vehicle but the rear bar was not 20mm. as advertised but 16mm. so i contacted the seller and they confirmed that they don't carry rear 20mm bar. so they refunded me some money for the incorrect rear bar and let me keep it. but it doesn't even fit. its too long and the ends are at an angle which the rear factory bar looks nothing alike. so i gave it to my neighbor to make art with. so I wound up buying a megan racing rear bar 19mm and got it the other day. It is beautiful and very well made and came with rubber bushings (did not use). so now I installed both sway bars and the car no longer has any body roll. its very nice. I recommend to anyone who has a gs to upgrade their bars.
#230
So I installed the Ebay "EMUSA" front and rear sways with Prothane bushings (linked above) and stock links. My GS400 handles like a different car now - on hard, tight turns it'll stay upright and lose traction before the body has a chance to lean. Faster, safer, smoother, and still rides as gently as before when driving in a straight line, but much more stable feeling at high speeds. This is amazing, and I'm surprised that Lexus didn't make them like this in the first place. Thanks for the help and recommendations.
How did you make your fit?
#233
Just go with the megan racing rear sway bar, you won't regret it. its a 19mm rear bar. very well made and has a stunning blue power coat finish. I purchased front and rear sway bar bushings from figs engineering. they are a really good design and come with the lube also. needless to say, the car handles completely different now.
#234
#235
Just putting it out there.
http://shopfigs.com/v3/index.php?rou...earch=sway+bar
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#237
#238
Mike
__________________
