Megan Front Upper Camber Arms vs SPC ball joint
Old 12-11-13, 09:32 PM
  #31
Stevenhy92
Stevenhy92's Avatar
I am looking into getting some camber kits for my 2IS also, I will be installing bags soon. I have universal aerosport bags. do any of you know if the bag itself will rub on the Megans? i had this issue on my tsx with skunk2 arms, i know its whole different platform but just hoping to get some info. don't want to get spc cause I will probably need more negative camber.
Old 12-12-13, 08:06 AM
  #32
heyarms
heyarms's Avatar
I have KSport air struts, so theyre a sleeved type bag, they clear the arm easily. I run the arms maxed out negative, gave me plenty of room to run more aggressive wheels up front. -3ish up front, -7 in rear at ride height.
EDIT: Using Megan UCA's in front. "Custom" Megan rear arms.
Old 12-12-13, 12:33 PM
  #33
Gville350
Gville350's Avatar
^But do you have the Megan UCA or SPC ball joints?
Old 12-12-13, 12:48 PM
  #34
heyarms
heyarms's Avatar
Megan UCA's.
Old 12-12-13, 05:23 PM
  #35
Gville350
Gville350's Avatar
^Very good; so I assume then you're on max - camber using them?
Old 12-13-13, 10:59 PM
  #36
Stevenhy92
Stevenhy92's Avatar
Nice, yeah i used ksport air struts on my tsx. this time around i went with universal air supsension aerosport bags. alot wider than the sleeves for sure. so im just hoping they don't rub on them. don't want them to pop cause of that
bbong
IS F (2008-2014)
12
12-15-17 05:29 PM
seivonecsu
Suspension and Brakes
07-10-13 08:51 PM
NafisC
06-21-12 12:19 PM
rcJten
03-20-11 04:16 PM
passnu2
14
10-13-10 08:15 PM
Quick Reply: Megan Front Upper Camber Arms vs SPC ball joint
