Car rocks front to back after installing coilovers
Old 05-21-13, 04:41 PM
Triton3k
Triton3k's Avatar
Default Car rocks front to back after installing coilovers
So yesterday I finally got around to getting my stance coilovers installed. I set the damper to "0" and after driving I noticed that when I would come to a slow stop at a light that the car would rock front to back alittle. I tried messing with the damper but still get the same results. Anyone ever experience and know what could be the problem. Also when I purposely shake the car from outside you can see it swaying oppose to it being stiff and barely even moving.
Old 05-21-13, 06:45 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Did you get an alignment done? If not, get one done. If so, allow the coilovers to break in and "settle" especially if they are new. The ride will get better. Good luck.
Old 05-21-13, 11:00 PM
Triton3k
Triton3k's Avatar
^No alignment done as of yet. I plan on doing it this week. But could that be the reason why its so easy to rock the car? The coilovers are 2nd hand and seemed fine but it just seems like something in the rear has play which i'm thinking now it may be the sway bar, but i'm not sure as of yet.
Old 05-22-13, 06:54 AM
RikTT
RikTT's Avatar
Regardless, an alignment would be in order after you've dialed in the height. Not sure if you're set on full stiff dampening (hard) or have super stiff spring rates.
Old 05-22-13, 09:43 AM
Dawa
Dawa's Avatar
+1 on alignment after coilover install or major suspension work.
after i installed my coilovers i had a stupid amount of toe in,
which would cause my tires to follow the grooves in some of the worse
roads on the highway and make me swerve slightly within my lane
Old 05-22-13, 09:03 PM
Triton3k
Triton3k's Avatar
^yes i'm gonna tryt o get the car aligned tomorrow and keep you guys update on if that fixes it.
Old 05-23-13, 06:13 AM
RikTT
RikTT's Avatar
Post up what is out of spec after the alignment. Also, approx how low are you F/R ?
Old 05-23-13, 09:09 PM
Triton3k
Triton3k's Avatar
will do. gotta wait til monday to get the car aligned.
Old 05-24-13, 02:44 PM
BayAreaLex
BayAreaLex's Avatar
Ok... If you give the car a good bounce at all four corners, does any corner bounce more than once?
Old 05-27-13, 08:28 AM
Triton3k
Triton3k's Avatar
^I have to try each individual corner and see what happens.
Old 06-01-13, 01:24 PM
8ll8lack
8ll8lack's Avatar
Check ride height. The back might be a bit more lower then the front. Lower the front end or raise the rear.
I had this issue after install the sc430 coilover on my gs. I had to mess with the rear spring perch for the preload.
Old 06-04-13, 12:57 AM
lexo98
lexo98's Avatar
I'm having the same problems on the Megan Ez's I recently installed.. I just got an alignment yesterday so Im hoping it settles in better.. I also noticed that I couldnt't ride all the way on the soft setting.. I had to turn it up about 7-8 clicks from the soft setting towards hard. I wonder if i should kick the rear up a lil more. Right now I'm close to the same height front and rear.. I measured from the highest arch on the wheel wells. I also gotta find somewhere more level to measure..
Old 06-04-13, 07:22 AM
RikTT
RikTT's Avatar
Also, try and get at least half tank of gas in BEFORE you finalize your desired ride height. Keep in mind yourself as weight ... I usually get all that out of the way, play with dampening and wait a week or 2 then head off for an alignment
xshurikx
Suspension and Brakes
05-23-16 08:08 PM
speed6
22
01-25-11 07:47 AM
farbyndrn
Southwest
19
05-30-10 11:10 PM
gman44116
12-01-09 12:40 PM
Quick Reply: Car rocks front to back after installing coilovers
