control arm bushings and ball joint
Im going to replace my bushings for control arms soon.. as i need them badly.
however i want to know, what the possibility of needing whole new control arms would be as opposed to just new bushings..
Do the sc control arm ball joints wear easily? Dont wanna buy bushings and then need whole new arms.. just a thought.
car has 201k miles and doubt the control arms have ever been replaced
thanks
thanks
In my own opinion, since my son drives daily my SC300 and in order not to worry down the road that the ball joint might wear out, I decided just to buy both front LCA. Also, I am planning to keep the car for a long time, I guess it is worth to buy the LCA.
once you take the control arm off you can feel the ball joint, a good condition ball joint will spin with some resistance and not have any play at all. if there is some play or if it is really easy to spin (meaning close to having play) then it is probably worn out.
what i have seen is the ball joint boot usually fails first, then dirt gets in and makes quick work of the ball joint itself.
I recently did the front poly bushings on my 1993.
First of all, buy new Front Lower Rear OEM Toyota cam bolts. They seize. You have to cut them out with a 4" cut off wheel.
The Stock steel sleeve will freeze to the bolt, so it's hot dog bun cut down the stock sleeve with half of your old Eccentric bolt seized to it, and an air hammer, and you can re use that one, or buy a new OEM bolt.
Also there is a vendor on the 'Bay that sells aluminum Front Lower Rear sleeves that wont sieze up.
With this Mod/Maint, the car feels like a hundred bucks up front!
Thank you!
20GS300
12-17-14 04:52 PM
