Question for CL Members with H&R springs
Old 01-03-03, 09:34 PM
PHML
Master Thread Closer!!
PHML's Avatar
Default Question for CL Members with H&R springs
Did you use stock shocks or aftermarket shocks?
How was the wheel alignment with the H&R springs?
Thanks in advance.
PHML
Old 01-04-03, 02:11 AM
GS4Will
GS4Will's Avatar
stock shocks are fine..they would wear out bit faster....i would say get the L-tuned or KYB shocks and install all at the same time
Old 01-04-03, 07:00 PM
drill
drill's Avatar
I have H&R springs with stock shocks going on about 20,000 miles since installation and no problems or leaks from the shocks whatsoever. Alignment was done at a local shop and was brought within specs. Handling is okay, I'm sure with aftermarket shocks it would be better. Kinda wish I had the shocks changed at the same time the springs went in to avoid taking the same things apart twice.
Old 01-04-03, 10:59 PM
PHML
PHML's Avatar
Thanks for the info.
PHML
Old 01-06-03, 04:17 AM
jawnthen
jawnthen's Avatar
had them with Bilsteins and 20s. Alignment was tough to nail down. I believe the rears were right at the tolenance. With the stock 17s there was no problem with alignment.
Old 01-06-03, 06:45 AM
bravo261
bravo261's Avatar
i am using stock shocks for now with 20's and all is fine. just do the new shocks if you can at all, but i didn't really know then and am doing other major things currently anyhow. but if you can, get shocks
Old 01-10-03, 06:41 AM
elclassico
elclassico's Avatar
Default what kind of shocks to buy?
l tuned? or is there something better? i heard they could be noisy. any feedback?
Old 01-10-03, 09:52 AM
LexFather
Guest
Posts: n/a
I'd go with the L0tuned shocks, they are only a lil over $200 bucks from Steve ganz.
Old 01-14-03, 01:47 PM
Hameed
EV ftw!!!
Hameed's Avatar
Instead of doing an L-tuned suspension mod, does anyone have experience with the H&R springs and Bilstein shock upgrade? I have heard it is better, plus you get a lower drop with the H&R springs - 1.5 inches as opposed to 1 inch with the L-tuned mod.
Let me know your thoughts on this mod compared to the L-tuned mod. I am leaning towards this mod instead. Please keep in mind that I have not done any wheel/tire mods yet. Stock 17 inch rims are still on the car.
Old 01-14-03, 02:21 PM
GS4Will
GS4Will's Avatar
Many here have HR+Bilsteins...it does provide slightly lower drop than the L-tuned. as far as which is better, they are both good
Old 01-24-03, 04:26 AM
PHML
PHML's Avatar
With the H&R Springs....are the gaps (front and rear) equal?
Is the rear gap a bit more tha front for the more aggressive look?
I know the Eibach springs have a lower in the rear compared o the front.
Any info will be appreciated.
Pete
Old 01-24-03, 05:00 AM
jawnthen
jawnthen's Avatar
I was always under the impression that the rears were a bit lower than the fronts. Dunno if that's due to the amps and sub in the trunk...But after looking at my old pics, it looks like the gaps about the same. Here's a pic when I had the stock 17s and HRs.
Old 01-24-03, 11:46 PM
PHML
PHML's Avatar
Jawnthen:
Thanks for the pics w/ tape measure.
ayotomy
Suspension and Brakes
01-26-15 08:18 PM
UCLAJimmy
12-17-08 03:46 PM
NVMYGS3
05-11-02 09:18 AM
xsuperjoex
08-17-01 10:05 AM
Quick Reply: Question for CL Members with H&R springs
