Brake Fluid Speedbleeder (is350)
Old 06-04-13, 10:08 AM
lasrx
lasrx's Avatar
Default Brake Fluid Speedbleeder (is350)
Who makes a good speed bleeder for the is350? Also where does one buy it?
Thanks!
Old 06-04-13, 11:16 AM
WylieKylie
WylieKylie's Avatar
If you want a Speedbleeder type system you need Earl's Solo bleeders:
PN 280025ERL for the front
PN 280041ERL for the back
(I'm sure someone will correct me if I am wrong, I don' thave these yet, but plan on buying them soon)
You can get those any number of places, Jegs, Summit, Amazon... Just do a google search and choose a place to buy them from. You can also do a search for Earl's Solo bleeders in this forum and confirm the part numbers.
Old 06-04-13, 01:22 PM
lasrx
lasrx's Avatar
Thanks for the keywords. I used it to look up the original thread (https://www.clublexus.com/forums/sus...o-bleeder.html) and these look like the right part numbers.
Old 06-13-13, 02:43 PM
lasrx
lasrx's Avatar
Tried it last night. The bleeders for the front was a perfect fit. The rears were a questionable fit and seal. Decided not to use the rear speed bleeders for fear of snapping them.
Old 10-14-17, 11:26 AM
WylieKylie
WylieKylie's Avatar
Dredging up an old thread here, but I've got some additional information.
I purchased a set of the Earl's Solo Bleeders and managed to lose them before I got them on the car. Now I am in the process of replacing my frozen rear calipers and I need a way to bleed the system. As luck would have it I had a set of speed bleeders sitting around, Russell PN 639570 that just happened to be a perfect match for the rear calipers.
Edit: Two things from looking up the part numbers of the Earl's that I supplied above. First, I'm sure that I got the part numbers swapped front to rear. Second, assuming the front part number is right from Earl's I've looked up an equivalent Russell part number.
Front: Earl's PN 280041ERL or Russell PN 639560
Rear: Earl's PN 280025ERL, or Russell PN 639570
I haven't tried the Russell front part number yet, I'll post back when I install them in a couple of weeks.
Old 10-29-17, 01:10 PM
WylieKylie
WylieKylie's Avatar
One last follow up for those that may need this in the future, I can confirm that the Russell part numbers I posted above work. The front bleed screw is a bit shorter, which scared me a bit when I installed them, but it works perfectly. With the stock bleed screw there is still a-lot of thread that isn't engaged in the caliper, there is a-lot less of that with the Russell part. Yesterday I replaced both rear calipers, put the Russell Speed Bleeders in all four corners and bled the brakes. Worked like a charm, the pedal is more firm, and with the new pads and rotors on all four corners initial bite is better.
Also, since it took me a while to find this information, I'll put it in this post. The proper order for bleeding the brakes is:
1. Left Rear
2. Right Rear
3. Right Front
4. Left Front.
DaveGS4 (10-29-17)
Mr2KiEu
08-26-23 09:30 AM
RageRacerM
04-16-18 11:18 AM
Ericspyder
11-23-17 12:39 PM
smokyis350
10-22-13 12:43 PM
wushuboy
Suspension and Brakes
12
10-17-13 06:40 PM
Quick Reply: Brake Fluid Speedbleeder (is350)
