Megan Racing Street LP vs BC Coilovers
I am trying to decide between the 2 coilovers. If they were the same price I would go for the BC without question but I found the Megan LPs for 800 which is quite a bit cheaper than I have found the BCs. I do track the car a few times a year so I am mainly interested in improving the performance of the car. Will only be dropping the car about 1.5 inches. Does the performance of the BC warrant the $200 price difference?
yes spend the money and get BC...the LP are actually 12/8...the website may say 12/10 but it's not...they did a typo error and haven't changed it....you will feel the difference clearly when driving...well worth the extra 200 for comfort and rebuildable
Dampers wear out, and your valving/damper needs may change (if you decide you want different springs in the future you may want the dampers re-valved for the new springs).
If you can rebuild or replace the dampers at a reasonable cost it is going to save you money in the long term. BC Racing's website lists damper replacement cost at $95, and the FAQ's also talk about their ability to re-valve the dampers
I don't doubt that the Megan Racing coilovers are a good product, but their website doesn't list the cost of a repacement damper, and says that they DO NOT re-valve their own shocks.
EDIT: I stand corrected, just found on Megan's website where they list the damper repacement cost of $115. So if you are confident that you will be happy with a limited set of spring rates over the life of the car I guess they would be a good option.
