Steering shakes..
So I have searched around and found some similar issues but I am trying to nail this down to the specific problem.
My steering wheel shakes side to side when driving at lower speeds and when braking. I also noticed that as I was backing out of my parking spot yesterday it made a strange jerking noise.
When I get my speed up around 50-80 the problem seems to go away....
Any ideas?
Any ideas?
sounds like the lower control arm bushings are bad. mine does the same thing. does it pull realllly hard on grooves in the road and on bumps? and kind of pop when you hit the brakes after backing up. common problem on sc's. also your steering rack bushings are probably worn out which can cause a shake at speed too. i replaced mine with battle version solid aluminum bushings and its so much better, still have to do the control arms though...
Yea, when I am pulling out of a parking spot it kind of pops. Not all the time but sometimes... which is kind of weird. What's a fix on that cost wise?
Originally I was thinking warped rotors but I am not so sure since it does it even when I am not braking. Not to mention the strange pop i've heard while backing out...
