Slammmmmmm!!!!!! Tein Flex's
After a long, much awaited wait, I finally got my Tein Flexs and got them installed. I spent most of last night, from 10-3:30, with my mechanic installing the Coils. After everything was said and then, my car is officially slammmmed. Maybe a couple rotations out of my taste, but that as well as a balance and alignement are going to be done or in a couple of weeks, to track tire wear. Otherwise, my softness and hardness are a little too soft for my likings as well. So far after 30 min of driving, the ride feels great much like stock but with the lowness. I am gonna make em harder tonight. Will follow up.
Its is preety low
little tuckage
maybe a little too low for my taste
i wanted it kissing the top of my tires, not tucking
its scraping a litlle
but the piece its scrapping with is my undercarriage, which got screwed up last yr after running over some roadkill :X
but going back today and getting fine tuned
was getting too late last night
little tuckage
If you did not get the car aligned yet the negative camber might actually be helping you from hitting the fender. But that also depends on your offset. I would be careful if you keep it slammed and get it aligned. Make sure there is nothing blocking if you hit down hard or you could bust something.
Northern California Regional Officer
Thanks to RMMGS4, I can actually drive now As most know, we had to melt (mold) the wheel well plastic, cut holes in strategic locations and bend some metal. A total fix! No rub!
There you go Syn..... Great, I'm feeling the drop with no rubbing now... Before I thought you should raise it about 1/4" to 1/2" but you held your ground and now your looking great with no problems...
