Race Tech Rotors
Old 01-09-03, 02:15 PM
SandRock
SandRock's Avatar
Default Race Tech Rotors
Should the Race Tech Rotors be turned(cut) before installation? I read that a couple of other guys that have them say the cad coating on the rotor surface wore off.
Old 01-09-03, 10:27 PM
rominl
exclusive matchup
rominl's Avatar
umm..... never heard about it. don't you just install it and use the pads to eats up the rotor area that the pads are in contact with?
Old 01-10-03, 09:16 AM
SandRock
SandRock's Avatar
Could you re-phrase that
Old 01-10-03, 12:29 PM
BananaGS
Tech Guru
BananaGS's Avatar
that is called bedding process. you don't need to resurface new rotor. The cad plating will wear off, that is normal.
you will have to go through bedding process for new rotor or new brake, some called "break-in period"
here is how:
http://www.empire1.net/racing/neonracer/tech.shtml
look under Powerslot rotor break-in
Old 01-10-03, 12:47 PM
JacobT
Guest
Posts: n/a
I have RT(Racing Technology) rotors on my GS. The cad coating do get worn off after 50 miles of driving. Do you expect the coating stay on the surface as new? You can do it by NOT applying brakes when stop
Old 01-10-03, 03:52 PM
PAULGS430
PAULGS430's Avatar
Thumbs up Yeah bro.
Yeah bro. I had Power Stop & Power Slot & both end up that way. It's perfectly normal dude.
Paul
Hey man when the weather gets warmer we should hook up wit
Philly-Cat, nudderGS400, & me for a mini local meet just to check out the rides bro.
Old 01-10-03, 11:17 PM
SandRock
SandRock's Avatar
Some people say that all rotors should be cut (new or other wise)before you put them on. I think in the cutting process the cad surface would end up on the floor. What I was trying to get across was, is it ok to put these on without cutting.:eek:
Old 01-10-03, 11:24 PM
SandRock
SandRock's Avatar
Default Re: Yeah bro.
I put up a post a while ago about the same thing. Me and Lextacy400 meet at the Franklin Mills Mall sometimes. Its another car meet place up in the northeast that we should all go to and rep Lexus(in the summer). He says he is the only guy wit a Lex up there.
Old 01-11-03, 01:50 PM
JacobT
Guest
Posts: n/a
No. You don't need to cut them before install. Just remember to genetly break in those new rotors for the first 20 miles.
Old 01-11-03, 03:42 PM
rominl
exclusive matchup
rominl's Avatar
yeah i never heard about the cutting part too. but i do believe the very first time you instaleld new pads or rotors, it's to drive hard (10 to 20 times hard 60-0 stops) and then let the whole thing cools down
Old 01-11-03, 04:32 PM
SandRock
SandRock's Avatar
I heard of someone that purchased new rotors that were warped so they cut them before they put them on. I put them on this morning. Everything went ok except a fitting piece missing out of the kit. They broke in fine. Thanks
Old 01-11-03, 05:10 PM
rominl
exclusive matchup
rominl's Avatar
ah ic. well i believe if a rotor is made good it should be good surfaced to begin with
Old 01-12-03, 01:20 PM
SandRock
SandRock's Avatar
Good point. The rotors look good on my car but I cant say the stopping power has changed. Im going to give it a little more time.
Old 01-12-03, 02:23 PM
Received 2,466 Likes on 1,618 Posts
New rotors the same size with the same calipers won't make any difference. You might slightly decrease brake fade after repeated hard braking with drilled and/or slotted rotors. Steel brake lines will improve brake pedal feel but not stopping power.
Stopping power comes from bigger rotors, more powerful calipers, and most of all, stickier/bigger tires.
Old 01-12-03, 05:28 PM
rominl
exclusive matchup
rominl's Avatar
and by theory, with the same size slotted / drilled it might hurt stopping distance coz' you get less surface area
Quick Reply: Race Tech Rotors
