when it just isn't low enuf...
started with HR/Bilstein combo...
https://www.clublexus.com/gallery/sh...t=1&thecat=500
then a CL marketplace deal...
then read up what other CL members issues are...
https://www.clublexus.com/forums/sho...threadid=68320
fix the problem on your day off...
mini write-up on HAs vs HR/Bilsteins
well I've been dealing with the rubbing issue for the past 2 days so, I haven't had much time messing with the damper settings.
At the lowest setting on the HAs, it feels a bit more comfortable than my bilsteins. Currnently running 0/1 settings. The other setting I had was up at 11/12 which was way stiffer than the bilsteins. I didn't have time to find at what setting it would match the bilsteins. One thing that I want investigate futher is the ratio of front to rear dampning. I will play around with the settings and try to give write-up on what happens. I'll try my best to quantify the results.
but so far I really happy I made the switch. I should have listened to some folks and gone straight to the coilovers. The drop is where I want it and I can tweak out my handling to suit my mood (once I get the EDFC of course).
Guest
Posts: n/a
Another 20" Dronell CA-05's?! Looks like we are wearing the same uniform
I have those 20's on my ride for 10 months now and never have any kind of rubbing problems. I thought +38 offset is just perfect for our GS. Maybe it's the weather in N. Cali. is different than TX
exclusive matchup
jacob, how many figure gap you hve? that might be the reason
btw, just to let you know, i raised my front up a LITTLE bit (1/4 inch) and now everything on my alignment is within spec, even the front camber! that's awesome consider i have the HA and you know how low my car is
Northern California Regional Officer
Nice work Jawnthen! You and I are twins now! With some plastic cutting and some minor metal bending I am all good! No rubbing and zero finger, baby!
Hey BLVD king - make sure you are familliar with the silver color change from 99 to 2001. I see that you are looking for a 2001 and they have a gold overlay ontop of the silver compared to the staight silver in 98/99.
Good luck with your search!
thanks guys for all the comments...i just got back from a trip to LA and lemme tell you that I bottomed out a couple of times on the 5. But I had 4 adults in the car plus a trunk full of luggage. Man the wheels were tucked by about 1/4 - 1/2 inch. :eek:
I thought I raised it enough for the trip but I guess not enuf. One other thing I was thinking of to help was to increase the damping. I wonder if that would have helped with all the weight in the car? I was running 2/3. But I didn't want to make the ride harsh cuz I was driving with my folks and my aunt.
Oh I wish I had the EDFC during the trip. I could have fiddled with it and found out. It was too much of a pain to get to the back dampers cuz the trunk was full of luggage. Guess you know what my next mod will be
exclusive matchup
hahah 2/3 was so soft man, i am running 7/6 (tried 8/6 and 7/5) as well, and i have had tons of stuff in the car before, but i never bottom up my car before on the same route (i know what route you took, hehe). maybe you should try that, the stiffness helps, though i think the springs determines more
romlin,
you have no clue how many freeways i took today.
405
5 again
580
680
80
680 again
580 again
880
still think you know the route i took?
but back to the bouncy issue. so you're telling me you had about 500-600lbs of stuff in your car...remember I had 3 other ppl riding with me plus their luggage. It will be hard for me to test this without the EDFC. I don't usually drive with my car packed like that. At the height it is right now and just me and a full tank of gas, I don't bottom out at 0/1.
405
5 again
580
680
80
680 again
580 again
880
