Can I run 255/35/20 without spacers ?
Since running 20's is not about handling I don't see why you'd want 255s vs 245s. A 255/35/20 is over 6% bigger (1.7") in diameter/circumference over stock 17s so your speedo will be that much off (low reading).
I had that setup with a +41. But changed it to a 245/35/20.. Do the 245/35 it's better because you might encounter a slight rubbing when you have the wheel fully turned with a 255...
Originally posted by MasterG
I want the 255/35/20 for the slight wider width. The wheels will be protected a little more. The roads in Pennsylvania SUCK.
Check out the tire size calculator over at miata.net to get a better idea of the sizes available to you.
Tire Calculator
emad2007
04-23-14 01:44 PM
