KW v3 installation
I know that the KW v3 install requires use of the stock upper strut mounts, with modifications to the fronts.
Has anyone bought new OEM strut top mounts or aftermarket ones so that the stock suspension can just swap out and KWs swap in?
If so, did you use OEM or aftermarket? I can find KYB and Moog front strut mounting kits, but the only rears I find in aftermarket is rear "lower" strut mounts. Are these what are needed on the KWs? Do the fronts even include everything I'd need to make the KWs complete bolt-ons without disassembling the stock assembly?
If OEM, what part #s are needed?
Thanks anyone that has some insight!
Ok, my bad… I was just trying to help; hopefully someone here will give you better information.
By the way, I have done this installation.
Those other top hats/ strut mounts are the only ones that may be available; however I do not see any benefit on using them as they are the same style as the OEM ones. If you want solid pillow ball’s mounts you could get some custom made, as I do not know of any company making those, or contact other shock companies like Buddy Club/ Megan to see if they are compatible with the KWs and maybe you can use those.
The parts that you need are in the KW V3 installation manual, if you don’t have it, you can find it online here: http://www.kw-store.com/products/kw-...it-v3-153.html they have the PDFs in that page, just make sure that you pick the correct car/application.
I understand that you already looked there…but the OEM parts are listed there, that is why I posted the link…and what you need is in the instruction manual for the KWs that I posted above, but you probably looked there already. So I do not have any other information, hopefully someone will reply soon with what you need, but I do not think that too many people have these KWs here. Good luck with the installation.
I'm ok using another set of OEM parts.. I don't recall seeing the part numbers in the installation instructions and the diagram you gave had a lot of pieces.. I wasn't sure which all of the pieces I needed.
I don't want pillow ball and the only reason I was looking aftermarket was for a "complete kit" and/or price. I.e. the KYBs are $60 and I don't wanna pay $300 for a set of OEMs.. if that's what it ended up with.
Thanks for the input!
Hey erichb, I did the Kw v3 install yesterday and boy I tell you what, its a pain, the upper front mounts don't fit the kw upper mount that is purple, so i end up not using the purple peace and went directly on the stock upper mount, its working fine till I find a solution to the matter.The rears upper mounts worked fine but not the fronts.
I hear that the 98 supra front upper mounts work find but just remember..
All the upper mounts on the sc center has to be drilled out to fit the threading so it can go in.
Im talking about the sc300, not sure if its the same
99custom
Suspension and Brakes
12
09-07-14 06:25 AM
Ariyanna
02-11-08 05:48 PM
