Upper ball joint cost??
Just had my timing belt and water pump done. Lexus recommended changing upper ball joints, their price: 1650$ is this ridiculous or normal?? What will happen if I don't change them because I can't afford that.
Lexus dealers are always going to overprice parts and labor. Its not necessarily the ball joints you need to replace but the entire arm. These are very pricey units on the Lexus. There are a lot of cheaper alternatives to replacing it but you also need to consider the car that you are driving. You can go cheap and go with the ones from ebay, you can go with the various different brands from rockauto.com or you can spend some more money and go with the OEM ones from Sewell. Whichever route you take, have a shop install them rather than a dealer
Yeah my mechanic advised I change mine as they have alot of play so I'm looking for some as well.
Having trouble locating anything decently priced though. OEM seems to be $500-$600 per side. Seems a better idea is to go after market adjustable arms, but they're not that much cheaper.
Hope my suspension doesn't fall apart while I'm procrastinating laying down >$1000 for 2 pieces of metal.
Can anybody tell me is it a very difficult thing to replace, I mean if I brought them could I do it myself? I'm no mechanic by any means but if I have a DIY and its not terribly difficult I'd try, seems like you'd just take the old one off and replace with new one? You'd probably need an alignment after though correct?
If your car is lowered, look at SPC or Megan for the aftermarket adjustable arms.
If not, look on the auction sites for aftermarket replacement arms. For under $250/pair
will a worn out joint affect the alignment? i tried getting my alignment done but the shop said the upper ball joints need to be replaced. at least i think he did, his engrish was difficult to understand.
The upper control arm for the front suspension is definitely one of the easiest things to replace --- but requires patience, and at least 1 special tool -- any Autozone type place should have it (something like a ball-joint remover) to remove the ball joint stud from the vertical caster arm. Also, the hardest part for me besides the rounded castle nut which required 2 hours of fking with, was an hour aligning the 2 hinge bolts back into the frame of the car, as they pass through the arm bushings and you cannot see the ends.
You can get an aftermarket upper control arm (front suspension) for $100-$300 on the net, or local auto parts, or check with Sewell for an OEM ~$368.
Part # 48610 and 48630 for left or right side control arm assembly. Comes with the castle nut, and cotter pin.
http://lexus.sewellparts.com/oem-cat...S430-2001.html
